APS F body reinforced MAF delete hose
Guys, Here's the first pic of the APS F body twin turbo system MAF delete hose, this part will be released by the end of Sept 07 if all goes to plan. Do you guys like the steel reinforcement rings on ther MAF delete hose? This will ensure that the moulded 4 ply nomex reinforced silicone hose can cope with quite high boost pressures. Pm me if you'd like to order a MAF delete hose as I only have very limited numbers.
Peter
http://www.airpowersystems.com/fbody/maf_d_1.jpg
Peter
Originally Posted by 99Z28LS1
i love the stuff that has yall's name on it. everything looks amazing APS, great stuff
Peter
Originally Posted by wildta
Does the APS kit not work woth a MAF ?
Peter
Originally Posted by Brains
I'll probably just end up with a chunk of 3-1/2" steel tubing painted black..
Peter
i completely agree.. the last thing u need is a chunk of rust going in the intake... plus stainless is a lil easier to shape.. but it warps real easy when u tig weld it.. try to use 1/8" if u go to make one
Originally Posted by smokinHawk
on the intercooler were you guys use the rubber groment IAT sensor, is it able to be tapped for the threaded IAT? also what is that other boss above the iat for?
Thanks,
Peter
Originally Posted by calongo_SS
Those bosses are not going to come tapped? It looks like they are tapped & plugged in the pic. Is that just a prototype piece? It'd be nice if they came tapped for an M15 meth nozzle.
Peter
7 Second Club
Originally Posted by peter@aps
No, We don't tap the end tank casting.................this way guys can tap the casting to what ever thread they need or require.
Peter
Peter
very smart move....
Originally Posted by bluecamaroz28
Looks great. What material?
Peter
Originally Posted by Fastbird93
Peter.....
Have you considered doing one of these MAF delete hoses for the C5 crowd?? I have a 2 Bar SD tune in my car but I still have the MAF fuglying things up.
Peter
