Front end dive
Front end dive
Does anyone know of a way to get rid of front end dive without lowering the car, i have an STS and there is no way that i will be able to lower anymore than i already have...
exactly. I actually like the swaybar and konis..
lowering my car was a mistake. I dont really on the street at all like it except for looks.
the only advantage is the stiffer spring rate and lower center of gravity..
doesnt anyone make springs that retain the stock height?
I'm pretty sure that stiffer springs are the ONLY way to reduce brake dive without changing the weight distribution or suspension geometry. Shocks will help reduce how fast it reaches full dive, and sway bars will add a little spring rate due to a bit of bind, but that's all.
