probably a stupid question
anyhow, with hptuners hooked up, it's telling me that my right bank o2 sensor is dumping 90% fuel at idle while the left is at 10%. Apparently, this all happened after my header install. First, what would cause this? Also, what should i be checking?
i had the car scanned today.
the codes are P0133B Heated Oxygen Sensor Slow Response (Bank1)(Sensor1)
and P1133B Heated Oxygen Sensor Insufficient Switching (Bank1)(Sensor1)
Any help with this? I tried searching and just found that people were having trouble with the sensors not getting hot enough, but if that was my case i'd have a problem with both sensors instead of 1.
