Differences between Vette and Camaro t56s
Old 07-25-2007, 09:30 AM
legal disaster's Avatar
Default Differences between Vette and Camaro t56s
Hey all I was wondering the difference between the corvette and camaro/trans am T56? I believe I read somewhere that the corvette uses a different bellhousing and it has a different input shaft. Also it doesn't have the open shifter at the front of the core like on a f-body t56. Are these the only differences? And if so, can a corvette t56 be used for a f-body. I am also aware of the c5 Z06 M12 t56 that has more agressive gearing and lighter/stronger forks.
The reason I am asking is because I am close in my project of dropping a ls6/t56 into my 86 Iroc-Z and was wondering the differences between the two. Regardless of either one I get I was going to ship it out to t56rebuilds and have new forks and synchronizers put in, but would also like a more agressive gearing like the z06's M12 tranny. Thanks in advance, let me know if it will work.
Old 07-25-2007, 10:10 AM
A-Dub's Avatar
See if you can find a GTO tranny (maybe CTS V as well?). The GTO uses the M12 like the Z06, but the externals are the same as the Fbody
Old 07-25-2007, 10:28 AM
ls1 joe's Avatar
The CTS V won't work. You would need a GTO transmission.
Amber
Old 07-25-2007, 01:49 PM
ae13291's Avatar
dont the corvettes have the rear mounted trannys that are completly different?
Old 07-25-2007, 04:31 PM
Eurospec2's Avatar
yup
Old 07-25-2007, 04:47 PM
2002_Z28_Six_Speed's Avatar
The GTO shifter has an adapter to put it farther back than the F body version. About 5 cm or more. It was a big difference though. If you get a whole takeout you might want to consider that.
Quick Reply: Differences between Vette and Camaro t56s
