Having problems with fans!!
Old 07-28-2007, 04:10 PM
00JDAws6's Avatar
Default Having problems with fans!!
My fans still are not working and I have not found the problem. The car kicked two codes for fan relay 1 and fan relay 2 so I replaced them. Still no fans, I think I am going to try to switch out the sensor on the driver side of the block and see what happens any suggestions?
Old 07-29-2007, 06:19 PM
ae13291's Avatar
yes!!! when sensors get old the resistance increases and u will not have a proper functioning sensor and it wont enguage the fans at the right temprature!!! do your fans turn on when u turn on your ac system???
Old 07-29-2007, 10:20 PM
00JDAws6's Avatar
Yes I changed the sensor on the block it fixed the problem thanks
