Tuning LT1 with Tunercats-weird things..
Originally Posted by TwoFast4Lv
Has always been an issue. If you do not put your original gear ratio in to begin with and then do the conversion you get a corupted file.
Unfurtunately it usually messes up the original file unless you saved it some where else also like you should always do
Well- maybe thats what happened... I got another 94 Formula and used that file and put it into this one - fixed everything.- then i compared the one i pulled last night to the one i put on today and there were lots of things that were different..
Thanks for that info..
