I wonder if i can use boost to break this one!
Old 07-30-2007, 07:26 PM
navymitch12's Avatar
Default I wonder if i can use boost to break this one!
Well got all the new stuff and loaded up the truck to take it all to the machine shop.
My baby under the cover watching her new motor head off to be built!
Old 07-30-2007, 07:31 PM
8ALTNG's Avatar
nice. what size cubes are you going with???
Old 07-30-2007, 07:47 PM
6l
they are 4.01 pistons with stock crank
Old 07-30-2007, 09:11 PM
8ALTNG's Avatar
sounds like a nice setup. What are you throwing at it for boost and how are you getting it there???
Old 07-30-2007, 09:20 PM
haha....the car has had an sts kit on it for about a year...so stick with that
i made 480hp with 5.5psi and the stock (cam only) 347
so shooting for over 500 with same boost and the 6l....then once i get the fuel system to back it i will shoot for more...and well i still need to ditch the ls1 intake, stock heads, ...and a few other things b4 i go for glory.
who knows its just my daily driver so not looking for anything insane jsut something strong and fast
Old 07-30-2007, 09:46 PM
Navy David SS's Avatar
Very nice . Make sure you get your fuel delivery system squared away. 500 should be easy with this set up. 5.5psi? want to bet that doesn't last long
David
Old 07-30-2007, 09:52 PM
i am stuck on an island...without a track so it will stay at 5.5 for a while.
the fuel is ok for now....60# inj with a 255 in the tank
Old 07-30-2007, 10:05 PM
01ramair500hp's Avatar
LOL when i got my block from texas speed it was not rapped up in plastic.. and one side was scared.. so i have to get the block shaved already and its new :/
Old 07-31-2007, 07:29 AM
MIGHTYMOUSE's Avatar
ya, i would have advised against a letting a box of pistons hang off the edge of a skid.
good luck
Old 07-31-2007, 09:49 AM
$ho_tyme's Avatar
Any motor can be broke
Old 07-31-2007, 04:05 PM
yea mighty...it didnt necessarly look safe to me but it work...it all made it here without damamge
Old 07-31-2007, 07:55 PM
8ALTNG's Avatar
what size turbo are you going to use????
Old 07-31-2007, 09:55 PM
its a 67 with the sts kit...the plans are to see what i can max it out at some point put need fuel system first
Old 08-01-2007, 12:30 AM
99Z28LS1's Avatar
thats bad *** mitch...... 500 should be easy, i make that with the boost you have right now. you put that 6L in there and the right pistons/317 heads and 600 is in your motor no doubt
Old 08-01-2007, 02:00 AM
not using the 317 heads...the stock ones with the 13.7 cc dish should bring the compression down to a safe level for 5-10psi
i know i could make 600...just want to make 500 wish 5.5 psi....then go from there
Old 08-01-2007, 08:12 AM
Dumb Ass Vette Moderator
ls1290's Avatar
The injectors and pump will handle 500 to 550ish no problem.
Good luck with build and keep us posted
Keith
Quick Reply: I wonder if i can use boost to break this one!
