I have Z06 Calipers and TT2's.
Old 07-31-2007, 05:53 PM
BLOODTA's Avatar
Default I have Z06 Calipers and TT2's.
Ok, I just got some 04 Z06 calipers and I have Torque Thrust 2's, will I have any clearance issues up front?
Old 07-31-2007, 08:37 PM
Xsta Z 28's Avatar
Are you just swapping acaliper for caliper? If so no.
Or are you wanting the bigger diameter rotors too? If so yes. You will have clearance issues, the spokes curve inwards too much. A small spacer and possibly some massaging of the spokes will be necessary.
Old 07-31-2007, 08:41 PM
BLOODTA's Avatar
Just swapping out the calipers for now.
Old 07-31-2007, 09:53 PM
Flawless02SS's Avatar
I guess you have the f-body bracket and all.
Old 07-31-2007, 11:52 PM
CULATR's Avatar
so you can put the corvette caliper on your oem bracket and use your stock rotors right? but if you change to the corvette sized bigger rotor and all you have to do something about spacing on a tt2's right? swapping calipers??? Is that just the corvette bracket and the adapter bracket and thats all?
Old 08-01-2007, 10:56 PM
Xsta Z 28's Avatar
Rght.
Yes.
An adapter bracket is needed to mount up the C5 caliper & rotor to the f-car.
Quick Reply: I have Z06 Calipers and TT2's.
