I have Z06 Calipers and TT2's.
Originally Posted by Xsta Z 28
Are you just swapping acaliper for caliper? If so no.
Or are you wanting the bigger diameter rotors too? If so yes. You will have clearance issues, the spokes curve inwards too much. A small spacer and possibly some massaging of the spokes will be necessary.
so you can put the corvette caliper on your oem bracket and use your stock rotors right? but if you change to the corvette sized bigger rotor and all you have to do something about spacing on a tt2's right? swapping calipers??? Is that just the corvette bracket and the adapter bracket and thats all?
