what are 317 heads
Old 08-01-2007, 04:52 PM
99reddevilFRC's Avatar
Default what are 317 heads
got heads off of 6 liter iron truck motor (9-17-04 dated in oil pan) has 317 stamped on the side of heads, and exhaust ports are "D" shaped. please help someone told me they were LS6 heads, if so are they exactly the same comp ratio? thanks for any info.
Old 08-01-2007, 05:07 PM
mudflap1989's Avatar
I'm not the expert on this, but they are definitely not LS6 heads, LS6 heads are 243 castings, that is all that I can help with. I think that the truck heads have a bigger combustion chamber around 72cc maybe?
Old 08-01-2007, 05:09 PM
brad8266's Avatar
317 heads are truck heads with 72cc chambers. They will lower the compression of your engine and they do not perform as well as LS6 heads stock for stock.
Old 08-01-2007, 05:10 PM
Beast96Z's Avatar
Very similar PORTS to the LS6 heads, but the combustion chambers are 72cc's, which is a bit larger than the LS6.
Old 08-01-2007, 07:07 PM
StripedZebra's Avatar
Buy yourself a Procharger and throw them on
Old 08-01-2007, 07:29 PM
sroach20's Avatar
or a twin turbo.
Old 08-01-2007, 08:14 PM
transam45's Avatar
those heads are great if your going to boost ur car if ur not going 2 get some ls6 heads and if u want to sell them pm me
