shims in a BOV
Old 08-01-2007, 09:15 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
Default shims in a BOV
how are they used?i installed the new 1 without putting in any shims/washers and it seems to work fine,what am i missing?
Old 08-02-2007, 04:22 PM
ddnspider's Avatar
bump.
Old 08-03-2007, 07:58 AM
stevieturbo's Avatar
on cars with an airflow meter, you do not want the BOV open at idle etc, as it can **** of the AFM readings, as all the air is no longer passing thru it ( assumes vent to atmos BOV )
So some have adjustment to add more tension, so this scenario doesnt occur.
Some might use shims, others an adjusting screw to add tension.
If yours is working fine, and not leaking under boost....dont worry about it.
Old 08-04-2007, 12:01 AM
JAvenger007's Avatar
whats a good way of checking if it leaks under boost? or at idle?
Old 08-04-2007, 05:59 AM
Seal up your entire intake system, and pressurise it manually.
You will also need to apply pressure to the top side of the BOV too during this test, otherwise the BOV will start to leak once spring pressure is overcome.
On mine, this starts to happen at about 5/6psi.
Which perhaps isnt good enough ?? If I had 5psi drop across my IC core/TB, then potentially that BOV could start to leak under boost, if I was feeding the top side from the intake ( correct place )
Old 08-04-2007, 11:18 AM
so the BOV needs to be capped/plugged or does it need to have pressure fed through the top?
Old 08-04-2007, 11:24 AM
see above
Old 08-04-2007, 11:27 AM
ddnspider's Avatar
i thought the whole point of the source at the top of the BOV was to feed it vacuum so between vacuum pulling the valve up and pressure from the tubing it pushing it open
Old 08-04-2007, 11:41 AM
it does that too...
But if you have say a spring of 10psi in there...once boost rose over 10psi, it would blow the BOV open.
SO boost is applied to the top, so this doesnt happen.
A spring strong enough to stop that happening otherwise, would make it imposible for the vac to pull the BOV open.,
Old 08-04-2007, 12:01 PM
ddnspider's Avatar
isnt the goal to see when or if the BOV cracks open at a given PSI?so giving pressure to the BOV source would hold it closed,so u could check for other leaks but not for the BOV itself correct?
Old 08-04-2007, 12:34 PM
you want to check for leaks on both.
But you also dont want to be running the absolute minimum spring pressure in the BOV that keeps it closed under boost. Keep it shut a,little tighter to be 100% sure it is never open under WOT boost conditions, or even some part throttle boost conditions
Old 08-04-2007, 12:49 PM
ddnspider's Avatar
i may just throw a couple shims in mine just to be safe for when i go to higher boost
Old 08-04-2007, 02:23 PM
Thats what confused me. So we need to cap one side of the charge piping along with a guage and then pressurize from the other side along with adding pressure to top of the BOV?
Old 08-04-2007, 03:01 PM
ddnspider's Avatar
ok heres the way i see it.
to test all your intake piping you cap off and connect a pressure source right off the turbo along with pressurizing the BOV so it stays shut.
to test the BOV let the car run and rev it to redline and let out and have someone see if it opens when u let out.or u can pressurize the system and not give the BOV a pressure source and see when it opens
Old 08-04-2007, 03:29 PM
Which is what I said.
Yes, you can do this under full load on a dyno. Revving it with no load on the engine, would be pointless.
Old 08-04-2007, 03:32 PM
ddnspider's Avatar
i wasnt arguing with u i was concurring with what u said.i read on another site that revving it in neutral and then watch the rpm when it comes back down to idle and if it fluctuates for a sec u know the bov opened
Old 08-04-2007, 03:36 PM
sorry...
although that last sentence makes no sense to me
Old 08-04-2007, 03:51 PM
ddnspider's Avatar
sorry...
i googled b4 i started this thread.some BOV company said that if u rev the motor up when it comes back down to idle if its not smooth or takes a second to idle regularly then its because the bov opened and vented some air.that didnt make alot of sense to me which is why i started the thread
ddnspider's Avatar
stevie what did u use to cap off and pressure test stuff
