Quick question about shocks
LS1TECH Sponsor
absolutely not
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
That's what I do Revalves for, each set is valved to the use/and spring rate of the car. The idea is to get you the damping needed.
__________________
Sam i will call you next week i need to know what i should order.
Do the revalved blisteins provide as good of a ride, as far as comfort, as the konis(single adjustables)? Or is it better just to spend the extra 210 for the konis?
Do either of these come with a warranty of somekind? I remeber reading that some people installed konis, then they went out a short time later. I am BROKE, so i cant afford that happening to me.
Thanks!
Thanks!
LS1TECH Sponsor
Konis you can tune to you liking, Revalves you can't. You depend on me to set them up to your liking. I'm pretty good, but I'll never claim I'm perfect. Further Koni's have a lifetime warranty, the Revalves do not.
__________________
LS1TECH Sponsor
Unless you do something stupid to break them, they will replace a broken one if you need it. They will not just arbitrarily just send you 4 new ones for no reason.
__________________
That's what she said...
One of the rear adjusters on my friend's cars broke the hell off on us. They sent him a new one no problem, he simply had to send the broken one back after he got it swapped.
