Rear Main Seal Questions =*(
Ok so when i had my exhaust done recently i noticed oil on the transmission and undercarraige of the car. After looking at the usual suspects (filter, drain plug) they were both suprisingly clean so i moved onto rear main seal and it has oil all over the bottom of the connection. Sooo i guess im going to be getting a rear main seal done soon at 40k miles >=-O How much should i expect to pay just for labor at a decent shop. Also where is the best place to order the kit so i dont overpay for parts? I dont have the means where i live right this second to do it myself unfortunately. Thanks in advance everyone!!
You say it has oil all over the bottom of the connection. Bottom of what connection? Where the tranny and block come together?
I had to replace mine at 80k and I did the clutch at the same time. The only parts you need is the seal itself. May as well throw a new TC or Clutch in there if you are A4 or M6 as the tranny has to come out anyway.
The way I was sure it was my rear main was jack up the rear end of the car. As it got higher, the tilt of the car caused all the extra oil in the bell housing to come out. Replaced it with the clutch and all fixed.
You can expect to pay as much as it costs to replace a clutch for the rear main. 350 or so probably.
I have drops of oil all over the place in my driveway from the car too and it looks like its coming from where the tranny meets the motor yes. I assume its a rear main but dont have a real good way of getting a picture of it right now. If i can get by a shop sometime and get it on a lift i could get a pic.
its enough to leave ugly drops in my driveway and leave me with sticky oil residue on like half the underside of my car so that alone is reason to fix it. ill check to see if its the oil pan.
