Parting out feeler thread need help with highlighted things
Hey guys im kicking myself in the but i need help on what the items highlighted below would sell for, also if u see any prices out of place please tell me.. man u never know u have so much into a car till u do this
Tryed to Take off the most I could on things.. can't lose to much being i'm only 18 and i never drove the car :-P mind you this car from when I got it built the motor bought everything below saw 3,000 miles maybe 3,200 at max some of the stuff was put on halfway aswell got reciepts some of the stuff
Performance
58MM Professional Products Throttle Body (Polished, Never Installed) $190
MSD Opti Spark.. $400 (Cosmetic Marks) 600 miles
MSD 6AL $170 (Just Warrentied through MSD) 3,000 miles
MSD Blaster Coil $35 3,000 miles
QTP Electric Cutout (Borla) $105 2,000 miles
Borla Cat-Back (Dirty) $450 ? miles
ORY $120 ? miles
2x Bosch O2 Sensors (can get them warrentied at autozone if they are still covered) $85 500 miles
Hooker Super Comp Long Tube Headers (Coated, Dirty/Oil) $400 ? miles
Seal-All Metal Reusable Header Gaskets & Collector Gaskets $35 300 miles
Comp Cam 1.6 Rockers w/ CC Poly Locks $200 3,000 on rockers about 1,300 or so on the locks
1LE Aluminum Drive Shaft $85 ? miles
LE Stage 2 Heads + Port Matched Painted Red Intake w/ CC Springs good up to the 306 Cam, ARP Studs ?????? 3,000 miles
Ford Racing Red Top Injectors 36lb Injectors $110 ? miles
Suncoast Ram Air Intake (K&N included) everything to install<< complete kit $250 1,000 miles
Underdrive Pulley + Belt (not sure on % pretty decent I imagine) $50 ???? miles
Transmission
Fully built John Goebel 4L60E.. Have Spec Sheet PM me $1900 3,000 miles
Vigilante 3000 stall (refreshed/restalled to 3,700 by goebel) $500 3,000 miles
Get both for $2300
XXX Company Transmission Cooler $50
all 3 for $2325
Cooling/Radiator/Waterpump
Electric Water Pump comes already pressed in a red painted wp housing (Mezeire) $175 (for 8$ more a drilled 160 stat comes with) 3,000 Miles
ALMOST NEW A/C DELCO Compressor got it year and half ago sealed in the box thinking the car was gonna be a DD, has 3,000 miles on it.. only used for about 1,500 maybe 1,200 (when I brought it to my AC class and filled it up) $175 3,000 Miles
==Rest of A/C System (i replaced the seals 1,500 ago but since im taking it apart I recommend the $5 autozone kit.. holds freon fine and everything was vacuumed after install/remove) $90 ? miles
--Dryer
--High/Low Side Lines
--A/C Condensor
--Cant think of anything else post if i missed something
Stock Radiator Flushed about 3-4 times due to the a/c delco opti failing on the car @ 800 miles so out came the coolant, we flushed for good measures $85 ? Miles
Goodyear preformed Radiator Hoses (tryed to save money on the build then got sick of coolant leaking so i bought them) $35 1500 Miles
Suspension/Brakes/Rearend
10-Bolt rearend, New auburn Posi, Richmond 3.73 Series 2, T/A Girdle $400 (see about shipping/pickup) 3,000 miles on posi carrier/gears/girdle
LS1 Brake Conversion w/ new seals.. Caliper=Red Bracket=Black New Pad $175.. 600 miles on pads/seals
LT1 Rear Brakes Caliper=Red Bracket =Black New Rotor/Pad extra $40 to the above or $50 seperate 2,000 miles
LT1 Front Rotors/Pads $50 800 miles
UMI Torque Arm (Never installed) $195 0 miles
UMI LCA Relocation Brackets (Weld-In *Never Installed) $75 0 miles
Lakewood Lower Control Arms $87 3,000 miles
4 Bilstien Shocks/Struts w/ BMR 1"-1.5 lowering springs (lifetime warrenty on shocks struts) $600 600 miles
Adj UMI Panhard Rod $100 (or $90 if u buy the shocks/springs) 600 miles
Rims/Tires
17" WS6 Rims (00-01) Polished w/ Clearcoat Stripped curb rash on 3-4 (not noticable from 5 feet on any)
2x Goodyear Eagle F1's with 3-4/32.. 2x Falken Ziex 512's Brand New 100 Miles Before car was parked
2x Nitto 555DR's still wrapped in discount tires wrapping
Falkens and Nitto's have DT Road Hazard Warrenty
Would like to get around $900 for the set..
Engine Block
Fresh Rebuild, .30 over Lt1 355 Block Painted High Temp Black
TRW Forged Pistons
Stock Rods (Checked/Shaved @ machine Shop)
Stock Crank (Checked/Shaved @ machine Shop)
New Freeze Plugs
New Main/Cam Bearings (not sure on company believe eagle or clevite)
ARP Rod Bolts
ARP Head Studs
Exterior
2 Headlight Motors, neither grind 1 was cracked around the motor/gear housing area was j/b welded and fixed $80 each or $150 for both
2 Sylvania Ultra Bright Sealed Beams $25 for Both (3,000 miles)
2 Projector (look like clear euro things) Housings with H4 bulbs and conversion harnesses (never used) $55
Interior
brand new window motor with that resistor mod thing done so it will last forever.. has lifetime autozone warrenty (never used) $50
1995 *like new* Black Door Panels complete w/ switches/grills (2 of the switches are new) $250 (going off ebay price) ?????
Black Carpet, Was taken out and shampooed right before car was parked soft/clean very slight stain around where 94-97 console used to be $85
Digital ODO Cluster Conversion for 94-97 Firebirds/Camaros $90
Center Console 98-02, New Lid, Painted Interior Black $95
Center Console 94-97, New lid again (got a spare to I think) $80
Front Leather Seats (Charcoal/Black) Wear on Drivers where u get in $250 get the replacement part below for $45
Rear Leather Seats (Charcoal/Black) No Tears or anything $125
Back-Part Leather replacement cover for Driver/Pass Seats (whole piece your back is against, charcoal/black) $90 buy the seats and this is $45
Brand new Redone headliner $90 (will have to see about shipping?)
Performance
ORY $120 ? miles
Transmission
Get both for $2300
all 3 for $2325
--Dryer
--A/C Condensor
Rims/Tires
Engine Block
TRW Forged Pistons
New Freeze Plugs
ARP Rod Bolts
ARP Head Studs
Exterior
Interior
