How do you port an intake manifold?
Old 08-04-2007, 04:28 PM
Asmodeus's Avatar
Default How do you port an intake manifold?
which areas of the runners need to be touched up? does the mouth of the intake need to be altered? My intake is aluminum, and the bottom is detatchable so I can get to the runners.
I will probably open up the mouth to 96mm in anticipation of the 96mm TB they are releasing, clean up any casting flash inside the runners, gasket match the ports/match to the heads.. should I touch anything in the runners?
Old 08-04-2007, 05:04 PM
Phil'sC5vette's Avatar
I thought I saw something on the corvette forum once, but I havent seem it on here.
It was how to port a FAST 90 with pictures
Old 08-04-2007, 06:07 PM
Asmodeus's Avatar
a link would be AMAZING I don't frequent that forum so I can't even search there.
Old 08-05-2007, 02:58 PM
Asmodeus's Avatar
bump!
Old 08-10-2007, 04:53 AM
Old 09-09-2007, 02:39 PM
I just got my FAST90/90 and I can see I can take out more flashing that blocks air flow. Did you ever get additional information ?
