Valve spring installed height
I'm installing a set of Comp Cams 918 springs and need a little more installed height. Using the stock retainers the installed height of the springs is about .760. I need to know how to get the height up a bit as there are no extra shims under the springs. Can I get offset keepers, if so who makes them adn which ones do I need?
Thanx
Re'
Thanx
Re'
Thanx
Re'
Thanx
Re'
Do you have the integrated seals on your car or did you take them off and replace them with just a seal?
what cam? You can get away with installing them at 1.750" if you're running .600" lift or less. I actually recommend it if you have aggressive lobes.
If the're gonna break because you got a bad batch that will happen no matter where you install them.
Re'
Originally Posted by vettenuts
None of the springs setup at 1.800, even the stock ones. I think you are fine with your current installed height, as long as your cam isn't too aggressive.
I'm running a MTI Stealth II with .581 lift.
Re'
Running a MTI Stealth II with .581 Lift on both. The springs were rated at .600 lift and with the lower installed height I figured I'm about .020 short. By the springs specs I still have about .080 till coil bind. Am I OK??
The real coil bind number for a 918 is around 1.080.
Originally Posted by 5_02ls1
thaqats not an agressive cam...agressive=vindicator ms4 trex.....ect ect
Re'
