SLP lid problem w/pics
the first and second pics are the over lapping on the front of the lid the third is were it dont want to do down around the corners so its kinda bowed in in center of the lid and the third is the gap on the sides which is really as big as i thought but i dont know if it should be like that or not
the thing might be right so i figured i would let you guys take a look
thanks for your help
the front of the lid is behind the lip
becouse if the front of the lid is hanging over it the clips down want to fasten down
i think the problem areas on the two corners and its causing it to bowe in and the side to stick up mabey if i shave off the corners a little bit were the lid will go around them that might cause the lid to go down right
the circled parts are hanging over on the part is square is trucked behind the lip hopfully this will help you out
I had the same problem with the one on my 99z. I cut the smooth bellows off about .250in and was able to get it back far enough to get it to lock. The other problem that I was having was the lid was not sealing on the air filter so it would let dirt in. I ended up putting weather strip on the inside of the lid to make it seal on the filter. I am not impressed with the fit of the lid.
Tech Resident
Originally Posted by 1979transam
haha this might be a dumb question but i am new to LS1's so what is the smooth bellow?
yeah i still have the stock
could someone post a pic of what the lid is suppose to look like when on the car so i will know what to look for if i just happen to get it on there right
thanks
thanks
Originally Posted by ChocoTaco369
Is the hose connecting the end of the lid to the MAF/throttle body ribbed or smooth? If it's ribbed, you have the stock bellows. If it's smooth, you have an aftermarket "smooth bellows." The smooth bellows is, IMO, a huge waste of money as it provides next to no gains but is known to crack/misshape/bend/bow lids due to having no flex. The car was designed to require flex in that area, and the smooth bellows doesn't provide that. That's why I'm sticking with the stock ribbed bellows.
Tech Resident
Originally Posted by 98Camarod
SLP smooth belows allow for the flex. The fernco mod is the one that I believe you are referring to.
All "smooth bellows" designs stink IMO. I've seen them all crack lids and cause fitment issues. Nothing will allow more flex and provide better lid fitment than the stock bellows. Save your time and money on the smooth bellows mod. All you're doing is wasting time and money and sacrificing lid integrity for next to no power gain.
Tech Resident
I disagree, the slp ones are the only ones that are worth anything. This is especially when running a wet setup and the nozzle doesn't fit into the stock piece so well. I'm going to be getting me the smooth bellows.
For over $50, you can put gas in your car and drive the hell out of it for 2 weeks. Instead, you decide to give it to SLP for a piece of plastic that does nothing to increase power output. Dude, if you're just going to throw the money away, give it to me
You can get brand new NGK TR-55 plugs and MSD plug wires for about the same price as an SLP smooth bellows. Please, if you want to spend the money on your car, spend it on something the car will benefit from. If you don't believe me, research the smooth bellows a little. There are countless complaints and no proof of it doing anything to provide power gains.
