I need help fast
I need help fast
So i did my headers last night, and now i have a horriable miss. i cant even go over 40 miles per hours, ive checked everyhting, made sure all the plugs and wires on on right, everythign... what else could it be?
none of the plug gaps got smashed did they? and just for ha has.....while putting in the headers you didnt unplug the main harness for the ignition coils, and if you did, you plugged both sides back in.....sounds retarded but ive seen that happen
the plugs never came out, they are only a few thousand miles old, and never got in the way,the wires are new, because we ripped one getting them off.
i checked the main harness, and they are brand new o2's but im gonna go check to make sure they got plugged in right or something liek that, im not tripping a code for a primary o2
i had this same problem after my header install and i sprayed water on the plug wires while it was running and kept hearing arking so i put new plug wires on and it was fine after that!...Also make sure you bought the right o2's that could cause a problem also!
cracked a plug, i got it all fixed up, but it seems like i still have a slight miss, but its getting tuned next week so they will get it all fixed up than. but at least i can drive it now
except my y pipe rattles on the floor board
