ARP crank bolt torque specs?
Old 08-10-2007, 03:24 PM
01WS6/tamu's Avatar
Default ARP crank bolt torque specs?
Do I follow the oem procedure or is this a simple torque to X ft/lbs and forget it. Thanks Chris
Old 08-10-2007, 03:30 PM
vettenuts's Avatar
You will follow the procedure until the new bolt is installed including installation of the damper, use old bolt to seat, then take measurement.
Then, the torque is 190 lb-ft with ARP lube on the threads and under the washer for the ARP bolt. If you follow OEM you will break the bolt.
Old 08-10-2007, 05:43 PM
DONAIMIAN's Avatar
Be sure to get a hold of an instalation stud so you wont damage the threads in the crank.
Old 08-10-2007, 09:11 PM
01WS6/tamu's Avatar
Pull the oem bolt down to 240, remove it and then torque ARP to 190 with blue loctite on the threads. I do not have any moly based grease will a standard high pressure temp grease like mystic jt-6 work as well. I am just getting back to it now.
Quick Reply: ARP crank bolt torque specs?
