djnoclue416
08-11-2007, 02:51 PM
I want to spice up the life of my 02 bird and decided to purcahse HIDs for the low beams and the fog lights. Does anyone know where to purchase a conversion headlamp with a H4 opening that fits my bird. The dimensions of the stock are 3 and change x 5 and change. I think I came across somewhere online that stated 4x6.5(or 6) would work with little modification. Is this true? I would like to make sure before ordering. Thanks.
toplessHO
08-11-2007, 08:54 PM
I would advise against using the HID bulb kits.
The light output is bright but it blinds oncoming traffic.
Im currently installing projector HIDs from an 05 GM into my
97. But mine are 165MM.
I currently have Hella 165MM conversion lamps(replace the sealed beams)
and they use H-4s.
I have installed Hella FF-50s in the fog lamp holes and wired them for highs only.
These are driving lights and kick azz.
I have the luxury of extra headlight assemblys still mounted to put it all on the workbench and work on my conversion.
I could do the same for 98+ if someone supplied the complete header mount and headlight assembly.
