Rear wheel bearing replacement question
Old 08-13-2007, 04:31 PM
OldeSkool's Avatar
Default Rear wheel bearing replacement question
How far into the rear axle tubes do the rear wheel bearings need to go?
Do I just whack them in until they wont go any further?
Thanks
Old 08-13-2007, 05:15 PM
ROCNDAV's Avatar
Not too far. the seal has to fit. If you are hitting the outer race, you'll feel it when it stops.
Old 08-13-2007, 11:01 PM
98RedZone's Avatar
Yeah, you will feel it stop. Your not using the bearing and seal in one are you.?
Old 08-14-2007, 09:16 AM
OldeSkool's Avatar
no, the "kit" from autozone? no
I'm using stock style- separate bearing, separate seal
Old 08-14-2007, 07:38 PM
bradl1982's Avatar
Is there a write up anywhere on how to replace a wheel bearing.
Old 08-14-2007, 09:52 PM
RoadHazard's Avatar
LOL. You moved here. Someone already answered your post in the other forum too.
Anyway, there is a notch in each side axle tube where it stops the bearing from moving in. You just keep hitting the bearings until they seat on these notches. Of course don't hit on the bearings directly but use something to rest on the bearing cage first, like an old bearing or the bearing race driver that you rented from Autozone.
Old 08-15-2007, 01:49 PM
OldeSkool's Avatar
you caught me
i just had to make sure i did this job right the first time
