Lunati Cams?
Old 08-16-2007, 07:31 PM
WiseAssJester's Avatar
Default Lunati Cams?
I've read quite a bit on cams around this forum.
And I see quite a few people netting some very good results from a cam only(plus bolt ons) set up.
Right now I'm looking at a Lunati cam, and I'm wondering if anyone has any dyno proven or track backed experience with them?
I'm looking at a duration of 232/242(at .050 lift) and a lift of .544/.560 and an LSA of 112
My goal is anywhere around 380 to 400 WHP with a full true dual three inch exhaust. Think that cam will come close? I'm at 5500 feet altitude wise, so I wouldn't be too surprised to wind up a bit lower then that.
Thanks in advance for any help.
Old 08-16-2007, 09:20 PM
gts500's Avatar
Why lunati MAN ?? go for custom grind cams chek out TSP or TR or LG ,MTI
you will find a proven custom cams that will perform better than lunati .
do a search .
Old 08-16-2007, 11:17 PM
Eh, I'm lucking at my options at the moment. The actual cam swap is a few months out and I was wondering if anyone had tried the cam out.
Old 08-17-2007, 05:43 AM
gts500's Avatar
i see... this cam has a pretty high duration, i think you will needs heads to suck air to match up with the it , plus lift looks werd to me 544-560?? if i where you i would go for somthin like TR 224-224 563-563 112 or TSP 228-228 588-588 112 ,it would perform better all around cam.
but if you gonna do the lunati i expect your car to produce 360-370 .
