h/c package? input....
Old Aug 13, 2007 | 08:38 PM
ls1adamls1's Avatar
Default is 550 rwhp possible?
this might be a duplicate thread and im sorry if it is, but im planning on doing a h/c swap along with an intake. i am looking to get 550-600 at the wheels. i have a fully built tranny, 12 bolt, bolt-ons, exhaust.
i was thinking of going with ported ls6 heads, with a fast 90 intake and tb, but what cam would you recomend???? SUGGESTIONS????
Old Aug 13, 2007 | 08:46 PM
ls1leadfoot's Avatar
look at my sig........508rwhp
Old Aug 13, 2007 | 11:59 PM
ls1adamls1's Avatar
anybody have suggestions????
Old Aug 14, 2007 | 09:44 AM
N4cer's Avatar
Harris Speed Works if you want 550+ on stock cubes, hydraulic roller.
Old Aug 15, 2007 | 07:33 PM
Brian Tooley Racing's Avatar
I've never seen any information on anyone making that much power on a 5.7 stock shortblock, do you have a link to a post or anything?
Old Aug 15, 2007 | 07:39 PM
ls1adamls1's Avatar
i dont have any info....thats why im seeing if its even possible.
Old Aug 15, 2007 | 07:40 PM
HEMIETR's Avatar
N/A? Never happen.
Old Aug 15, 2007 | 07:43 PM
ls1adamls1's Avatar
ok well i guess that sums it up. ill let everybody know what route i take, and the dyno results, i hope i can get 525. we'll see.
nitrous may be in the works to achive my goal.
Old Aug 15, 2007 | 07:53 PM
Vette-Red's Avatar
A huge cam, all the bolt ons, trick flow or afr heads(milled to 57 or 59cc's), rr's, ported fast 90/90 might get you a little over 500, but that would probably be peak horsepower and may not do you much good on the street. Like a lot of people say look at the under the curve power and don't concentrate just on peak #'s.
Old Aug 15, 2007 | 08:08 PM
N4cer's Avatar
Heads, cam, bottle or boost. I need a link for that? LOL! Come on Brian! He never said NA.
Old Aug 16, 2007 | 07:58 PM
Asmodeus's Avatar
You are definately going to need nitrous to achieve your goal.
1) You aren't going to sniff 500 at the wheels with ported GM castings.
2) You have an A4.
3) The cam you would need to make big power would require a high stall.
4) High stalls eat power.
You should be happy if you break 450 N/A.
Old Aug 16, 2007 | 08:19 PM
Demonicbird00's Avatar
talk to Vengeance. they were able to prduce 521/450 out of a vette.
i think the only way to achive near 550 will be...
full bolt ons
M6 w/ aluminum flywheel
stock rear w/ stock gears
CF DS.
and titanium stuff in the drive and valve line
it will never happen in a a4 NA
-brandon
Old Aug 16, 2007 | 09:58 PM
ls1adamls1's Avatar
ok, thanks for all the info. well i guess i need to decide if i want to stay with an ls1 or go to a different motor. well i guess we'll see what i put together, and see what numbers i put down.
Old Aug 16, 2007 | 10:01 PM
Bullet_WS6's Avatar
uhmmmm... first off if im correct id hafta say you will shred the 12 bolt with that much power... and second off... the heads you chose arent the BEST to get up there but can be done... and third off... TREX cam but thunder racing would be my choice on a stock cubed motor but what kind of gearing are you running cuz with that kind of cam to get use of the range you will need something like 4.10's to get you started
Old Aug 16, 2007 | 10:10 PM
ls1adamls1's Avatar
ok well i will either build the ls1 and add a power adder or check out other motors and see whats better.
Old Aug 16, 2007 | 10:11 PM
Bullet_WS6's Avatar
if you want that kind of power you cannnnnnnn do it with the stock cube... but not easy... if your looking at new engine look at tsp lq9 408 iron block... if you got money get a short block and build it up... if ur tight go for tall block and just get some nice options to grow on later
Old Aug 16, 2007 | 10:29 PM
ls1adamls1's Avatar
this maybe a dumb question, but why would you go with an iron block if you are always trying to reduce weight?
Old Aug 16, 2007 | 10:32 PM
Bullet_WS6's Avatar
it can hold more power... and its not really a huge diff... the lq9 yes is heavier but its got so much more potential/ more cubes its welllll worth it
not even positive if it weighs that much more, i know three people with it done... mean my friend and fast... all in the 10-11 range
Old Aug 16, 2007 | 10:47 PM
Bullet_WS6's Avatar
btw i looked it up and its only 60 lbs more.. take your spare out and you're in good shape
Old Aug 17, 2007 | 07:14 AM
Cam02ss's Avatar
I previously had a H/C combo w/ the T Rex that made 463/402 on a mustang dyno. 4.10s weren't enough to make that thing get up and go- had to bump to 4.30s. I had an M6 though. I've got an LQ9 iron block 408 now and I think that would be your best bet if you're going after that kind of power. I'll be spraying mine with a 200-300 shot.
