Headlights wont work!?!?!?!?
Old 08-16-2007, 09:41 PM
2000TurboVert's Avatar
Default Headlights wont work!?!?!?!?
Hey guys..
My Head lights stopped working today..
Its a 2000 z28...
Heres the odd thing..
The fuses are good..... I believe.. I checked them with a fuse tester...
The foglights still work, but I get no low beams or highbeams, and NO blue indicator on the cluster.......
Im stumped??
Anyone got any ideas???
Old 08-17-2007, 01:45 AM
Ttt!!!!
Old 08-17-2007, 03:56 PM
Anyone Know anything about this?!?!?!?!?
Old 08-19-2007, 03:49 PM
To the Top!!!! Going to the dealership on monday... SAVE me from the cost!!!
Old 08-19-2007, 05:17 PM
trans am1's Avatar
check the ground wires by the head lights, also i dont know if you have checked the fuses under the hood hope it works out for you
Old 08-19-2007, 07:13 PM
The healights are grounded and Ive checked the fuses under the hood...
Its there a relay under the dash or something? This is killing me
Old 08-19-2007, 08:01 PM
trans am1's Avatar
the only other fuse is in the das on the drivers side. i had the same problem about 6 months ago and mine was the grounds of the head lights also try to track the wire all the way back to the fuse box under the hood to see if they are cut or damaged
Old 08-19-2007, 08:23 PM
Which fuses do I need to take out and look at?
Thanks!
Old 08-20-2007, 12:45 AM
trans am1's Avatar
it should say head lamp
