Mcleod dual clutch..Flywheel won't fit over crank
This is on a 95 Z25 with the LT1. All the bolt holes will line up but the flywheel just won't slide on the back of the crank. It's like the center hole in the flywheel is just a tad too small. It will start to go over the hub but just won't go. Anybody ever heard of this?
Originally Posted by wrencher
Measure the crank hub & the flywheel hole with a dial caliper.
Then you will be sure there is a problem before contacting McLeod.
