meth or intercooler or both
Old 08-23-2007, 07:31 PM
jamesnorthprov's Avatar
Default meth or intercooler or both
installing procharger need advice on witch way to go, want to use meth and tuner said i dont need intercooler i am thinking why not both. any advice and details on one or the other or both. thanks, jim
Old 08-23-2007, 07:42 PM
thumpstick's Avatar
It's nice to have an intercooler just to be safe. You can always do both, but if you just have the meth kit and something goes wrong (IE: the pump dies, or you just run out of methanol) you might be in trouble. I don't have any experiece with superchargers and it probably isn't as much of an issue like it is with a turbo, but It's always nice to stay on the safe side.
sorry about the length, and good luck
-John
Old 08-23-2007, 11:03 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
both!
Old 08-23-2007, 11:06 PM
2000TurboVert's Avatar
I would def. go both, that way if you run out of meth. or the pump breaks.. You still have your intercooler!
Old 08-24-2007, 07:02 AM
Rickys S/C Z28's Avatar
well i would think that it depends on how much boost your going to run?? i mean if you are running 5 # then i think its a bit overkill but if you going over 12-15 pounds then hay safer the better
Old 08-24-2007, 07:35 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Both will get you there safely.
Old 08-24-2007, 07:18 PM
i will be running 7 psi until i get forged. i think i will run just meth for know with failsafes and when i change out motors next year and run more boost i will go with both. thanks guys.
Old 08-24-2007, 07:46 PM
cool!!!
PM me if your interested in getting one of our custom methkits!! Saves some cash!!
Thanks
Old 08-24-2007, 07:54 PM
EPP
EPP's Avatar
Smile
I would not recommend installing any type of forced induction on the street with meth and no intercooler, it's not worth the insurance an intercooler gives you.
Check out my complete ATI ProCharger D-1SC price. Bob
http://www.exoticperformanceplus.com....html?item=798
Old 08-24-2007, 09:00 PM
Jake@EPP's Avatar
Just remember, a intercooler is ALLWAYS there, with a meth kit you have to monitor the level. You remove fuel to run methanol, its worth the effects, but like any power adder, you have to be with the program.
Old 08-25-2007, 09:31 AM
bboyferal's Avatar
FMIC ONLY
or
BOTH
Old 08-25-2007, 03:58 PM
99camarosupersport's Avatar
I'm running both, 90% of the time my pump for meth is turned off though, so I don't even use it.
Quick Reply: meth or intercooler or both
