best intake manifold
i have a 98 trans am m6 with pacesetters 3 inch tsp catted y pipe and msd coils with slp cold air kit. i want to put a head and cam package on it later on but right now i want a intake so what is the best intake out there i been looking at a ls6 intake but is the fast intake or wiend any better . im lookin for low end power from 0 to 100
With the FAST intake, you CANNOT keep EGR. With the ls6 manifold you can ONLY if you have the one sold by SLP with the EGR mod done. They are $550 new, but I just got one on here for $350 shipped. got lucky
Really? This is an excerpt from the fast instructions:
4)For EGR use (1998-2002 Camaro/Firebird) you must open the hole in your new manifold. Use a large diameter drill and Dremel type tool to modify polymer (30mm hole). Be careful not to damage the upper diameter where the o-ring seals (fig.12).
And this is the link in case you want to read the whole thing yourself:
http://www.fuelairspark.com/Instructions/147.asp
You have to modify the Fast Intake to use your EGR.
You should base your Intake selection on your heads and cam selection. If your going with a "baby cam" a LS-6 Intake will serve you well and flow plenty. But if your going to drop 2.5K on a set of awesome heads along with the cam then a FAST 90 makes sense because your intake will be your bottleneck. Albeit a small one. I was going to use a ported LS-6 intake until the shop dropped it and cracked it. Then I got my FAST90 and went with a larger cam than originally planned. Though I do kinda regret the larger cam, can't just roll into it and go I have to downshift.
