trans swap
need help with trans swap
I have 2001 camaro with a 4L60E and I want to put a T56 in it. what all do I need as far as electrical
You tap into your center consol wiring harness for the reverse lights, electric hatch if equipped and clutch switch (to start the car). The speed sensor has the same connector as your auto, but you need to extend your wires. I believe the reverse lock out needs to be tapped all the way back the computer. But im not sure.
