SES after new muffler
Is there any reason why I'd get a P1371 SES code after only changing to a new Magnaflow muffler? A few miles after having it installed, I got a bit of stumbling and the SES flashed off and on. Took it for another drive, ran it up to about 80 mph and the SES came on and stayed on with bad stumbling. I took it to Autozone to get the code checked and it came back as P1371. Nothing else was done other than having the muffler installed. After they ran the code, the light went off and it seems to be running okay, but with a little stumble every once in a while. A new opti was installed less than 1k miles ago.
Does the computer need to adjust for the new muffler?
BTW, it sounds GREAT with the new muffler.
The code you have is related to your ignition system (opti-spark). check the wiring harness and connectors. possible causes are the opti-spark itself, wiring issues to the opti-spark, or pcm related. nothing to do with your muffler. hope this helps
