Tach install?? I need help
ps anyone wanna take a stab at letting me know if they think i'm in the 12's based on the mods in my sig, (my tune is extremely conservative) and i know this should be a seperate thread but i'm lazy
Plus, they look retarded due to their size.
Goto their website, they'll have a online manual. With that said, the coil (as least the older ones) have a yellowish wire that the tach reads off. If you really are having a beast of a car to merit that huge tach, you'll be running an MSN box, in which case it has it's own tach-out hook up.
Sorry to be an ***. Just get a shift light.
Same as you, not trying to be an ***, I was just looking for facts and help not personal opinions. Good luck with your formula!
Anyone else??
Not a real big drag racing fan are you?
Anyone else??
looks like you sumed up an argument between the both of you in 1 post
But I see most of those people running them on street cars that barely see the track, if ever. How often Dan's does, I'm not sure, nor am I concerned. I just assume, because by the sig, it doesn't sound like a track car at all.And of course I have TB Bypass mentioned, it's a dynoed 6hp. As far as a monster? Naw. You have a small cam in it and headers. It's also been tested that the MSD coil produces less voltage in the higher RPM, so you're only hurting yourself there.
Here, I did all the work for you even.
http://www.autometer.com/tech_instructions.aspx?sid=8
(I have a feeling this is the one you want http://www.autometer.com/download_instruction/407j.pdf)
Pic your model and read the PDF. If you don't have Adobe Acrobat Reader, then here ya are.
http://www.adobe.com/products/acrobat/readstep2.html
And if you're still stuck...
http://www.fierolt1.com/lt1_tach.htm
(Man, 5mins in Google does a person wonders doesn't it?)
Didn't mean to lash out at ya, i just get pissed when people write off cars with headers, and cam, that were owner installed. Most will tell you, as i'm sure you'll find out for yourself that installing headers, and a cam with the engine still in the bay is no easy task. But the results are well worth it, as for the hotcam, yes it is not an aggressive cam, i didn't realize I hadn't updated my sig, a few months ago I changed over to a grind Gm 847 (this is a beef cake cam) i'll update my sig
Eh I think a big tach is all in preference. I've had one in all of my vehicles, the first being a v6 86 Camaro. Even if I don't see the track too often, I really just like the thing. Granted you could just get away with a shift light, but my stock tach is also off by 300rpms, throughout most of the rpm range. I def. couldn't get away without a shift light, that probably keeps me out of trouble a lot.
