Can I use 1.8 roller rockers?
Old 08-26-2007, 09:24 AM
flynlow3's Avatar
Default Can I use 1.8 roller rockers?
This is what I have:
ls1 with GM hot cam and 5.3 truck heads cast 706 ( 2005 tahoe)
I want to upgrade my valve train.
I have ls6 spirings, magnum comp chrom moly hardened pushrods and wanting a bang for your buck set of rockers. I want a set of rollers.
Can I use a 1.8 ration over the 1.7? What would you use? and what would be my advantages and dis advantages?
Thanks.
Old 08-26-2007, 10:18 AM
LS1 Tech Administrator
Patrick G's Avatar
Moved from advanced tech section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 08-26-2007, 10:42 AM
vettenuts's Avatar
Not sure the LS6 springs are up to task, I would upgrade the springs at the same time with a set of stiffer beehives.
Old 08-26-2007, 11:07 AM
Dragkid1917's Avatar
what are the numbers on the hot cam?
Old 08-26-2007, 11:55 AM
flynlow3's Avatar
GM Hot Cam w/ LS6 springs LSA 112, 218/227 Duration, 525/525 Lift. Includes LS1 camshaft (218/227 .525/.525 112 ) and includes 16 LS6 valve springs
This is what my cam card states.
Old 08-26-2007, 11:57 AM
flynlow3's Avatar
Some say I would possibly break my springs or they would wear out really really quickly. Is this true? or better said what is your opinion?
Old 08-26-2007, 12:54 PM
525 is like, a small lift increase from stock, i really dont see why any springs wouldnt work, the LS6 springs are rated to a .550 lift.
Old 08-26-2007, 01:08 PM
flynlow3's Avatar
Im dumb when It comes to the valve train. Im just taking advice from more experienced gear heads and going with what has worked for them. Lots of reading and learning but I love this kind of stuff. Would a 1.8 rocker make my lift any higher? If so can anyone give me a guesstimation on how much?
Old 08-26-2007, 01:41 PM
vidal77boxing's Avatar
Yes, u can use the 1.8 rockers on the gm hotcam. The rocker arms bring lift to 556. However, if you are running ls6 springs you will want to change them out to prevent valve float. Look into comp 918's and titanium retainers.
Old 08-26-2007, 01:44 PM
certanly.... right now with a .525 lift and a 1.7 ratio you have to divide out to find how big your cam lobe actually is. .525/1.7 = .309. To find out your lift with 1.8 rocker ratios, you would then multiply your raw cam lobe height (.309) by the new ratio (1.8) and you would get .309*1.8 = .556 lift. This also means that with that new lift you can not use the GM ls6 springs. You would need springs with a .600 max lift at least. However if your not going to change your cam, then slp makes a 1.85:1 rocker ratio, making your lift .571. With that duration your cam will feel like a decent sized cam, and not just a small upgrade from a stock ls1 cam. But if your plan on changing to a bigger cam, the higher rocker rations are not recommended.
Old 08-26-2007, 02:07 PM
flynlow3's Avatar
I am wanting to upgrade to roller rockers and I have the options of 1.7 or 1.8 with the set im looking at. I figured for the same price, Why not go ahead and get the 1.8 if my car can handle it. I may invest in some better springs as well.
Thanks guys.
Old 08-26-2007, 05:13 PM
you can go to 1.85 with that cam, did u c my math?
Old 08-26-2007, 06:52 PM
vettenuts's Avatar
Which rockers are you looking at? All rockers are not created equal.
Old 08-26-2007, 06:53 PM
Billf6531's Avatar
Would you happen to know the max lift on a set of stock LS1 C5 springs (non-Z06)?
Old 08-26-2007, 07:15 PM
Umm, actually I dont. It is an ls1 so i dont see why the springs would be different at all, however in any case id highly highly doubt they would be more then .550 max lift. What kindof lift do u plan to run
Old 08-26-2007, 08:50 PM
98RedZone's Avatar
Don't use them on anything but a stock setup.
Old 08-26-2007, 10:28 PM
david vericker's Avatar
I ran a setup back in 2003 with 568 lift Comp Ti retainers and the yellow Z06 springs and had no problems what ever....valve float was never an issue. A stock 2002 - 2004 Z06 has 550 lift.
Old 08-26-2007, 11:41 PM
if u guna do it just spend the money and replace it.... its not wirth the trouble of 300 bux for the upgrade.
Old 08-27-2007, 11:08 AM
Billf6531's Avatar
A friend wants to donate a set of lightly used 1.8 rollers to me for some work I did on his car. I have a stock C5 and thought that it would be interesting to install just those on the stock cam and see if there was any noticeable improvement in performance. Lift will be just under .510. I was reasonably certain that lift wouldn't be an issue, but I just wanted to check to ensure that nothing would jump up and bite me in the ***. I have HPT to tune with.
Has anyone changed just the rockers on a stock C5? Can you comment on the result? Anyone have a dyno sheet?
Old 08-27-2007, 05:07 PM
eallanboggs's Avatar
Just installed a set of the new 1.8 Scorpions on a 525/528 in a 4.8 Sierra. Used some Comp 918s some people seem to be so afraid of. No problems. Runs and sounds great. The owner loves it. Based on the formula the 1.8s add approx. 0.030".
Quick Reply: Can I use 1.8 roller rockers?
