Sponsored by: DashLynx
94 firebird h4 headlight conversion questions
Old 08-27-2007, 01:17 AM
jester1614's Avatar
Default 94 firebird h4 headlight conversion questions
I just bought a parts car and pulled these headlights out of it. they use a h4 bulb rated at 100/90W. I am trying to figure out how to wire them making them work properly via high beam and low beam. here is two pictures of the housing and bulbs.
Old 08-27-2007, 01:18 AM
jester1614's Avatar
the wiring is an absolutely a mess that will be cleaned up by me or my dad (a journeyman electrician).
Old 08-27-2007, 09:47 AM
Blackbirdws6's Avatar
I would simply buy an H4 adapter harness. That's what I did and it took me maybe 30 min to finish because I had to extend the wires a bit. Should save you a lot of hassle and I would be careful going with that high of a wattage for an extended period of time without a relay or upgraded wiring. That wattage is way above the stock wattage so you run the risk of burning your wires. PM me for the vendor of the adapter harness.
-brian
Quick Reply: 94 firebird h4 headlight conversion questions
