how fast has a STOCK lsx been FI
TwinturboCE...or somehting like that went 9's on a stock bottom end I believe with the Incon Kit. here he is. 3rd one down.
https://netfiles.uiuc.edu/nbrinkw2/B...boosted_03.htm
I know it's not the fastest but mines doing ok for a stock 346 and a stock 4l60e. It should be very close to nines with cooler weather and a better da, it was 90 with a 3300 da when it went 10.42.
Originally Posted by DrTurbo
Didn't Rob raymer go some 9's as well with his car and stock engine?
Jarrod "RICE ETR" on here has been 137mph and change in the 1/4
stock original bottom end, stock heads (original head gaskets), aftermarket 227 cam, t-76. i'm pretty sure he will squeak a 9 this fall.
RR ran a 10.17 @ 136 on an 'alleged' stock engine. I heard different
I ran 10.40s in a full weight SS with stock heads/cam (only 918s and headers), LS1 intake and all with around 8psi and a 50 shot so raymer's numbers are believable if you really push it I guess. Few nitrous cars in the 9s with a stock bottom end too.
Either way they will all hurt a piston sooner or later if you keep trying to go faster
Last year I went 10.20 @133 in a 99 camaro. zo6 cam 317 heads, stock intake, stock tb, stock bottom end. gt76 rear mount (mine) 3.00 gear 9 inch, 26x 11.5 x 16 et streets on stock camaro wheels. Da was about 2000 ft. Actual is 2200 ft.
The engine is still kicking, but the car is getting a 402 soon and the 346 is going in a 34 ford.
Whatever happened to Rob R?? He just disappeared....
RR? (never was very good at covering up my "writing style")
Originally Posted by black98ws6ta
That would be correct.
