water pump question
Old 08-30-2007, 06:22 AM
nebur8's Avatar
Default water pump question
my car is running hotter than normal around 230 i would say as oppose to the 180 from a week ago. Starting to smell some coolant also. when i touch the hoses going to the water pump the top one is hot but the bottom one is cool, however the lines going to the heater core are also hot. is this normal or is my pump going?
Old 08-31-2007, 12:28 AM
shaun's Avatar
its most likely your thermostat.a cold hose when the car is hot means the t-stat is stuck closed.
Old 08-31-2007, 06:11 AM
nebur8's Avatar
that would be the second time i replace the thermostat! the only reason i believed it could be the water pump is because i have a noise like a bearing going out from somewhere in the front. gonna have to tak e a look at it this weekend. any other suggestions/ideas would be helpful.
Old 08-31-2007, 07:42 AM
arcticwhiteTA's Avatar
Is it a chirp? kinda like a cricket? Mine does and it's almost a sure sign your pump IS going out.
