Can't Put Gas In My Car ??
Old 08-31-2007, 03:11 PM
Kratos 2250's Avatar
Default Can't Put Gas In My Car ??
I've got a 2002 camaro ss had a dianogstics test ran on my car and the code EVAP comes up no gas will go into my tank it's like it's stopped up no mechanic knows why it's doing this they think it's stopped up I know it's not could you guys please tel me how to fix this I have read the tech info on this code and it doesn't tell you how to fix it is it my air pump and should I take it out or dissconnect it?
Old 08-31-2007, 03:18 PM
Jon5212's Avatar
Sounds like you have an evap problem, what is happening is pressure is building up in your gas tank, its almost like trying to overfill a balloon. I'm not sure on how to rectify this situation, I'm sure someone else who has had this problem will chime in.
Old 08-31-2007, 03:20 PM
Sharpe's Avatar
This has been covered before, but I don't remember the answer.
Old 08-31-2007, 03:50 PM
crazymonkey's Avatar
possibility ???? https://ls1tech.com/forums/archive/i.../t-610891.html
Old 08-31-2007, 04:03 PM
nighttrain 1340's Avatar
Here is a long ago post from me.
https://ls1tech.com/forums/southern-members/660145-will-not-take-fuel.html
I have not let my tank get below 1/4 tank. Has not failed again.
The valve is behind left rear wheel well access panel. I havent looked at mine yet.
Old 08-31-2007, 04:06 PM
my01ws6's Avatar
my car never lets me fill up using the automatic thing that self pumps I always have to hold the handle....I wonder if this may have some reference to his problem?
Old 08-31-2007, 04:10 PM
Mine would blow gas back in your face. I used a coat hanger and pushed the check ball down and released the air in tank. Worked fine then.
Quick Reply: Can't Put Gas In My Car ??
