Southern Members A regional forum for all our down South members.
Will not take fuel
Old Feb 16, 2007 | 05:14 PM
nighttrain 1340's Avatar
Default Will not take fuel
Anyone have this problem? 2nd time this has happened. 1st time I had to pour about 2 gal. of gas before gas tank would take fuel. This time It wont even take gas out of a can. Both times I let the tank get below 1/8 . SES came on and its a fuel vapor code. Thanks
Old Feb 16, 2007 | 09:01 PM
m1key99WS6's Avatar
What was the exact code, I can try and research it with alldata pro, forums, etc?
Old Feb 16, 2007 | 10:07 PM
Mike I will get the code # tomorrow. I knew it last time it happened, just forgot the #. Thanks.
Old Feb 16, 2007 | 10:55 PM
Charlie@LsXperts's Avatar
should be code PO452, just dont let it get below an 1/8th tank, mine does that too and i have a clothes hanger in case it does. There is a ball in there that blocks the fill tube if you flip the car over... and if you have a leak in the evap system (gas cap etc..) it will close the fill tube to build pressure in the tank and you cant get gas in the car... i know its kinda dangerous but i just push the ball with a clothes hanger if it does happen but otherwise i just keep it above a quarter tank
hope that helps
charlie
Old Feb 16, 2007 | 10:59 PM
it will be a nightmare trying to find out where your evap system leak is, i bought a gas cap and a purge canister tryin to do this and ended up just blowin out the code and not lettin the car run empty
Old Feb 16, 2007 | 11:05 PM
hope that helps
charlie
Thanks Charlie. not alot of the folks know what Im talking about.Kinda hard to explain. That worked the first time (used a siphon sp. hose to push through the filler neck. this time no go. after a couple of hours if dropped out.
Gotta get this fixed.
Old Feb 17, 2007 | 08:38 AM
m1key99WS6's Avatar
I've never seen this before. I've ran my WS6 low a lot of times and this never occurred. If you delete this code from the PCM will it not perform this action again?
Old Feb 17, 2007 | 09:09 AM
Yep. If I run it low on gas. This is the first car I have had do this.
Old Feb 17, 2007 | 09:19 AM
m1key99WS6's Avatar
Check this thread out: https://ls1tech.com/forums/showthrea...ighlight=PO452 It gives a little insight on this issue.
Old Feb 17, 2007 | 09:43 AM
Yea Mike I might need to check for crimped evap line. Where is the Evap can on these cars?
Old Feb 17, 2007 | 10:15 AM
~JOSHUA's Avatar
I think it's on top of the tank. I saw a huge canister on top of mine when I had the tank out puttiing in a bigger fuel pump.
Old Feb 17, 2007 | 12:07 PM
the pressure sensor is exactly like a map sensor and its on top of the fuel tank too, delete the code and watch your fuel unless you wanna pull the tank IMO
Old Feb 17, 2007 | 12:28 PM
EVILWS6's Avatar
Boy these GM's are pieces of crap,aren't they? J/K
I 've never had this problem on any of my F-bod's before.Sorry,wish I could tell you something new that could help.
Old Feb 17, 2007 | 12:45 PM
I think everyone has spelled it out for me. Im not dropping the tank anytime soon. lol. Thanks all.
Old Feb 22, 2007 | 05:52 PM
hope that helps
charlie
Uh Charlie. We need to warn folks that that coat hanger trick will blow gas everywhere! Thanks for the tip. I let it get to 1/3 tank and it still did it. Now to wash the gas off my legs.lol
Old Feb 22, 2007 | 07:04 PM
C Murda's Avatar
hey so if i am to get rid of my evap system and delete the upcomming code will i too have this problem?
Old Feb 24, 2007 | 12:06 AM
yes it will spew gas so i just do it before if i know its gonna happen, if you let the fill tube get gas in it thats when it spews but if your below a quarter just do it before you pump
Old Feb 24, 2007 | 04:48 PM
C Murda's Avatar
there has to be a way of stopping this... i dont want to have to worry about runnin below 1/4 tank or even 1/3 ....
