Installing headers. What header gaskets to use? What bolts?
Old 08-31-2007, 03:52 PM
drain89's Avatar
Default Installing headers. What header gaskets to use? What bolts?
Tried search, but it just pulls up crap about LT1's.
Okay, bought used QTP longtubes. Do I reuse the OEM gaskets or get new ones. If so which kind?
Are the locking header bolts from Stage8 or Breslin worth it or just snake oil?
Don't want to waste money on something I don't really need.
What works?
Old 08-31-2007, 03:55 PM
95 Z28's Avatar
I got new GM gaskets when I did mine. A lot of people reuse them without problems, but I figured for the extra 20-something bucks, I'd make sure I wouldn't have to deal with leaks. As for the bolts, I reused my stockers after I cleaned them up a little bit.
Old 08-31-2007, 04:31 PM
GuitsBoy's Avatar
LT1's? Ill bet your confusing LT with LT1. LT is an abbreviation for Long Tubes.
The gaskets to get are the stock MLS gaskets. You can even reuse the stockers if theyre in good condition.
Old 08-31-2007, 10:14 PM
98Camarod's Avatar
Percy's
Old 08-31-2007, 10:21 PM
Numba1Stunna's Avatar
i got new stock gaskets, and dont waste money on the locking bolts. trust me they are no good
Old 09-01-2007, 03:00 AM
drain89's Avatar
No, it was from the LT1/LT4 section. You know the search around here. Great one minute, shitty the next or not working at all!
I can't wait till they get it fixed again. I like the good ol days of searching for what I need and not having to type up posts.
Thanks for the replies fellas. I think I'm gonna go with the stock gaskets.
I don't know what I'll use for bolts yet except that they'll be stainless.
Old 09-01-2007, 02:14 PM
SS4Luck's Avatar
new stock gaskets and cleaned up/new stock bolts
Old 09-01-2007, 02:55 PM
purdueranger's Avatar
reusable steel gaskets for me and on the 4 corners, i use studs so it makes taking the headers on and off a lot easier.
Old 09-01-2007, 03:10 PM
deadlift's Avatar
i used the stock GM gaskets. i havent had a leak yet
Old 09-01-2007, 04:45 PM
theblur98ss's Avatar
Reused the stock gaskets quite a few times with no issues. One at least one set of my headers the stock bolts were too long and I had to put a washer under them to reuse them.
Old 09-01-2007, 04:46 PM
JPH
JPH's Avatar
felpro #1438 and stock bolts.
Old 09-02-2007, 08:31 PM
kebie05's Avatar
where is a good place to get the stock parts from, other than the chevy dealer?
Old 09-02-2007, 09:17 PM
LS1Z28-00's Avatar
i reused stock gaskets and bolts no issues so far.
