gmmg questions
gmmg questions
whats the best solution to rasp when running gmmg w/ory
cat or muffler in the i-pipe? just want opinions, I need a louder exhaust tone the magnaflow is just too tame.
thanks
thanks
I was giving it a lot of thought myself...
semi cheap method is buying a $50 short Power Stick from EAD performance, trimming the Y on the necked down half, as well as the intermediate a good chunk, and just having it welded in (though I believe they're slip fit so you can do one welded side, one clamped if you prefer) ... slightly more expensive at about $115 I had also considered tossing a stainless high flow cat into that same area (doing the same as far as cutting down the Y and Intermediate and sticking it on in there)
just depends on what you're capable of or want to pay for really...
I'm ok with the rasp I have for the time being mainly because my current Y isn't a permanent setup, and am waiting to just more or less fab my own Y ... after I get my own Y done, then I'll see how bad the rasp remains.
Two problems with this though...
One, the power packs or power sticks are not stainless, this may deter some who want a fully stainless exhaust
Two, the way I want to do my Y pipe, one piece is not stainless, I'm still on the fence about this particular item, and it's a pre-made piece and not easily fabricated for the most part.
I like a multi-clamped Y pipe, ease of taking things apart, but may cause unnecessary turbulence in the end.
my vote is at the moment, a single small stainless cat at the end of the Y where it meets the Intermediate, but, I like stainless. It'll also cut down on that raw smell vs. using a bullet or a muffler, and shouldn't choke it down much at all since it's a single high flowing cat where the flow tends to be greater... hell it may even help pass an emissions check regardless of it's location (some people would pass it around here)
the XS ORY isn't the greatest, but it works, my biggest complaint about it is I've got a small exhaust leak on my GMMG Y/Intermediate connection currently, because both pieces are a little too long at the ends, and it pushed my GMMG out a bit more and I couldn't get it to seal up completely at that connection.
I'll probably be keeping the ORY and just cutting off and adding what I need to it, just because I honestly like the way it tucks up more than most, I just hate, with a passion, the Y merge on it
i'm curious to see what people advise on this. i'll soon be hooking my gmmg up to ARH lt's and an ORY. i'm hoping that the quality of the merge on the y pipe may help some but i'll have to wait and see. i do know that putting a cat on isn't an option. will definitely be some type of bullet or chambered stick into the i pipe...
Pontiacerator
I've just been through all this. I took off my GMMG and put a Hooker on it and the Hooker was just too quiet.
I now have the GMMG back on, a 2.5" Y with Carsound cats, a Flowmaster merge, and a Powerpack in the I. I didn't like hacking up my stainless GMMG I-pipe, but I like rasp even less. Even with all this, there is still some rasp. It sounds pretty good overall; the rasp is at a tolerable level.
i went from a magnaflow to a gmmg on my car. the sound is better for sure in my opinion. there is definatly more rumble to it. i do have LT's and a TSP catted Y-pipe as well. i do not notice the rasp on my car. maybe it is because i have cats or maybe it is because i drive the car and can't hear it from the inside. i actually wish i would have went with true duals. i would be willing to sell my gmmg and catted y-pipes if i wouldn't get screwed on shipping it all. it would weigh a ton and the box would be very large. the gmmg system is only a 2 piece system so it is pretty big.
Originally Posted by Tram
It's not that hard fellas..
Go get a 14" or 17" bullet muffler, weld it in just after the Y.. Your rasp will go away immediately..
custom y-pipe, bullet, or cats is what I know.
I have ran a catless oryp and that was hella raspy especially around 25XX rpms, threw on some cheap cartech cats and it sounded 100x better.
thanks
thanks
Yeh, I'm running Hooker LT's with custom orp with a bullet and then the GMMG..
If I had $15 every time someone told me they liked the way it sounded, it could have paid for half of it easily..
Originally Posted by RevGTO
I'm tellin' ya ... I'm runnin' cats and a Medium Powerpack from EAD with my LT's and my GMMG sounds really nice now ...
Pontiacerator
Originally Posted by Demon Of Dreams
my problem with that though is hacking up the intermediate and putting in a non-stainless component ... granted, that is my only problem... now if I were doing it, I'd save the stock intermediate and have a custom intermediate done with the chamber done into it so it remains a one piece to mate to the Y... but thats my personal opinion.
A custom I pipe is a good idea, but using the original meant fitment over the axle would remain perfect.
Pontiacerator
Originally Posted by BlueSLPCamaro
Anybody with Cats+Powerpack+GMMG have any sound videos? I have the Powerpack sitting in the garage, but I'm afraid I might not like it with my GMMG.
