What Turbo?
Old 09-02-2007, 02:04 AM
Dhmoto111's Avatar
Default What Turbo?
I have a 72 scout with an 01 5.3L that I am strongly considering putting a turbo on
What I want is more low end power but i dont want to spend 5k for a roots blower and I also dont want to gear down any lower than I already am because I have a TH400.
I want an increase in power and torque as low as possible, as far as top end goes I am happy with the power it has but wouldnt mind if it went up as a result. i guess i would like to end up with roughly 400-450 ft/lbs but I dont really know what turbo i should use to achieve this
Would something like this supply enough air for what i want?
T3 T4 T04E Turbocharger .63 A/R Turbo CIVIC EX B16 New
http://cgi.ebay.com/ebaymotors/T3-T4...spagenameZWDVW
thanks for the help
Old 09-02-2007, 02:07 AM
2000TurboVert's Avatar
Shoot me a PM,
STS offers a Universal Kit!
Uncludes
Oiling System
Turbo
Wastegate
Flanges
Gaskets
etc!
All you need is the piping!
Old 09-02-2007, 12:12 PM
Dhmoto111's Avatar
no one?
Old 09-02-2007, 12:38 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Originally Posted by Dhmoto111
no one?
A t04e is really to small, a turbo in the 67mm range would be the smallest i would go
Old 09-02-2007, 12:41 PM
LS1TECH Sponsor
DrTurbo's Avatar
Also if you want low end power, rear mount is not the way to go....
Old 09-02-2007, 03:34 PM
Dhmoto111's Avatar
rear mount is 100% out of the question, there is no way i would put it back there just to smash it on a rock, and constantly dunk the turbo in water and mud
i have plenty of room to put it above and behind my motor or on either side up high
Old 09-03-2007, 09:37 PM
Dhmoto111's Avatar
what about twin to4e turbos? I have more than enough room in the engine bay
i dont really want to buy a $1000 turbo for this
Old 09-03-2007, 09:44 PM
Do twin t04e's!!!
Old 09-05-2007, 12:50 PM
Silverback's Avatar
4x4 for torque… well, if I had a choice I’d adapt an eaton, wipple, kb… blower to it. Basically, that way torque output and boost will be proportionate to throttle position anyplace there is a load on it.
If you must use a turbo, I’d keep it on the small side to make sure that it spooled quickly, something like a pair of medium size T3’s, or something in the range of a T61 sized with a turbine almost as small as you’d use for a rear mount.
