Power steering problems with an old QMP turbo kit.
Anyone have some experience installing one of the old QMP turbo kits? I installed the new lines and the bottom of my power steering bracket is hitting the waste gate plumbing. Just wondering if this is a common problem or if something is off on my install. Not really sure what the easiest solution is other than ditching the power steering. Thought I'd check in here first and see what others have done. Would take a lot of clearancing on the plumbing itself...would also take a lot of cutting on the bracket to make it fit. Still not sure if it clears the actual pump housing. Has anyone else run in to this problem? I'll try to remember my camera next time I'm at the shop and take some pictures.
Thanks!
Chad
Thanks!
Chad
The "KIT" should have come with aftermarket lines, if it did not you should have some made. The ones that were supplied angled down towards the ground and then you routed the return inbetween the exhaust housing and compressor housing to the pump(slip connections at the pump). The feed ran towards the middle of the motorback up to the pressure side on the pump.
Originally Posted by chadtn
I was told it was one of the prototype kits...wish I could remember the name of the guy I bought it off of. Maybe he'll see this and chime in with how it was run on his car.
Thanks!
Chad
Thanks!
Chad
