Any known breakage of DART PSI beehive springs on BLOWER applicaions or good enough?
Really prefer dual springs but may be in the market for some DART 225 heads that come with the PSI single beehive springs good for .625 lift. The problem in my mind however is running up to 12 lbs of boost will create a lot more cylinder wall pressure and valve train abuse and are these springs good enough on a somewhat aggessive Comp Cam with XER lobes and specs of 224/230, .581/.592 lift, 114 +2 lsa? Will these springs be good enough for my application which will make around 700rwhp on 12 lbs of boost.
ALso, has anyone heard of one of the DART PSI springs failing yet?
