Do i REALLY have 2.73's?
Ok sry again for so many questions, but i KEEP ON seeing posts saying where 2.73 geared A4, can kickdown to first from 39-40. Mine wont go past 28mph! Do u think the previous owner swapped in 3.23's! I have the GU2 code. What else would explain my car not kicking down from at Least 30 mph with 273s!!?
Tech Resident
I have 2.73's and can downshift from 4th to 1st at 35 mph. The cutoff is somewhere between 35-36 mph. If your car won't kick down to first at 31-35 mph, that could mean a few things:
1.) Someone changed the stock tuning to not allow for it
2.) Your speedometer is off a few mph
3.) You don't have 2.73's
#3 is probably the answer. Go cruise at 70 mph and tell me what your RPMs are.
you post a video before of your 0-60... find the vid and look at then its shifting
At Wide open throttle...
2.73's the 1-2 shift will happen just over 50mph
3.23's I think the 1-2 will happen around 45mph
LS1Tech Administrator
Received 1,794 Likes
I can get a downshift to 1st at up to 36-37mph with my 2.73 car. Every time.
Do you want to absolutely, positively certain? Change your rear lube. While the cover is off, count the number of teeth and do the math. # of teeth on the ring divided by the # of teeth on the pinion.
http://youtube.com/watch?v=6dRf9eDBxU4
i kno my car shifts at 45 mph, its a lil hard to tell with tht video screen being small, and my shift kit kickin up the speedo a bit, but yea do shift at 45 mph, does tht mean i have 323's or could i still have 273s?
easiest way to tell is like what was stated above. Get on the highway in overdrive, do 60mph or 70mph, check your RPM, and report back to us. FYI at 70mph I'm at 1700ish rpm, and I've got the 2.73's. 3.23's will be about 2100 rpm at 70.
The best way would be to get on the highway as stated above but looking at the video above it seems like it just may be 3.23's. Its shifting at redline around 45mph.
hurley_21_07.. Is it shifting at 35mph right at redline? doesn't sound right at all to be shifting that early at WOT. If the spedo is that far off you should get a tune because the shift points, shift firmness, Lockup speeds.. all kinds of things use the speed input in the car.
Tech Resident
45 mph may be a little high for a 1st to 2nd gear upshift with 3.42's though...
ok i will, im leaving for work soon. So when i get to 70 mph, do i look at the rpms when im barely touching the gas, or when i push it just enough to where it accelerates and the rpms rise?
