Installing cam tomorrow..advance retard straight..
Well my motor is on the engine stand and bottom end is basically finished. I am going to finish the cam install tomorrow and wondering if I should just install the cam straight up or advance it? 232 238 .595 .605 111lsa 111icl
Phillip
Phillip
Re: Installing cam tomorrow..advance retard straight..
If you post all of your specs:Bore/Stroke/Head flow/valve size/and all the specs on your cam card I will put it in desktop dyno for you and see where the best power is.
On the cam card I need:
Intake opening degrees
Intake closing degrees
Exhaust opening degrees
Exhaust closing degrees
Josh
Josh
