Installing cam tomorrow..advance retard straight..
Old 05-31-2003, 10:40 AM
7 Second Club
Phil99vette's Avatar
Default Installing cam tomorrow..advance retard straight..
Well my motor is on the engine stand and bottom end is basically finished. I am going to finish the cam install tomorrow and wondering if I should just install the cam straight up or advance it? 232 238 .595 .605 111lsa 111icl
Phillip
Old 05-31-2003, 10:44 AM
JS
JS's Avatar
Default Re: Installing cam tomorrow..advance retard straight..
If it sez 111icl then put it in straight up..
Old 05-31-2003, 01:40 PM
NO CATZZ's Avatar
If you post all of your specs:Bore/Stroke/Head flow/valve size/and all the specs on your cam card I will put it in desktop dyno for you and see where the best power is.
On the cam card I need:
Intake opening degrees
Intake closing degrees
Exhaust opening degrees
Exhaust closing degrees
Josh
