can someone help with oil pump change??
ok my oil pump comes in this thursday (melling high volume oil pump) is there anything else i need before i exchange them??? thanks in advance...
yo howd ur cam work. Im dynoing now (2 day process) and its givin the tuner problems... what did u make with it.
Remember the shims on the oil pump if u have the double timing chain, if not, theres a hump on the pan so even if u do drop the bolt it shouldnt fall into the bottom of the pan. anyway lower the pan down as much as possible, loosen all bolts, and take out the 2 from the back of the bell houseing. It wont hurt to have a magnet around so if it falls it clings to that.
well im waiting on the oil pump to get her running which suks but jon from texasspeed said i should be well over 4200 but since mines a a4 with a big stall it ll eat alot of hp what cam u goin wit??
aww man what lsa did u go with?? im excited for i waited 4 months for my head/cam swap but i know it was its gonna be well worth the wait.. a friend of mine told me i should bout 440-450+ hp but well see, im gonna tune it my self if theres a way can u take sound clips of it at idle, while ur hauling ***, on the dyno also, and explain how the cam reacts at top end. low end, and dead stop.. thanks bro..
