need pcm info on a 99 LS1 (SS camaro). pin #s specifically...
Old 09-13-2007, 12:45 PM
kyles2000z's Avatar
Default need pcm info on a 99 LS1 (SS camaro). pin #s specifically...
this has nothing to do with diagnostics or tuning, but i didnt know where else to post it....this weekend i'll be installing a dual gauge pod in my friend's 99 SS. hes got a digital tach and an air/fuel gauge and im going to wire each gauge directly to the PCM and tap into the O2 sensor and RPM tach signal wires. i just need to know which pin#s to tap into and maybe what color the wires are for verification.
so, if youve got a diagram, post it up, or if you know which pin#s these two wires need to go to, post that up for me please. thanks in advance!
Old 09-13-2007, 01:31 PM
2001NBMZ28's Avatar
www.ls2.com/boggs/torques/99pinpcm.htm
Old 09-13-2007, 01:36 PM
Eurospec2's Avatar
Im curious, why are you gonna tap an A/F guage into the narrow band 02?
Old 09-13-2007, 01:43 PM
kyles2000z's Avatar
lol if youve ever seen the sweeping A/F gauges, none of em are accurate. all hes wanting is more or a light show (you can hate it or love it) so this will do just fine.
Old 09-13-2007, 07:42 PM
kyles2000z's Avatar
after visiting the link for the diagram, i cant find the pins im looking for. anyone with a 99 LS1 thats had to deal with the RPM signal wire and the O2 sensor wire please let me know which pins they are.
Old 09-13-2007, 07:54 PM
oange ss's Avatar
RPM = #10 Red Connector (white wire)
O2 Signal = #26 Blue Connector (tan wire)
Old 09-13-2007, 07:55 PM
2001NBMZ28's Avatar
All the pins/descriptions are there - #10 -WHT - Engine speed (tach) output signal, several 02 references?
Old 09-13-2007, 08:08 PM
sobaka__79's Avatar
for the a/f gauge use one of the kits from thunder http://www.thunderracing.com/catalog...vid=3&pcid=156
or just tap into the purple white wire on top of the drivers side fuel rail
Old 09-13-2007, 08:24 PM
kyles2000z's Avatar
thanks fellas, guess i was scanning it too fast.
