How do you change turn signal bulbs?
Old 09-14-2007, 11:55 AM
TA1364's Avatar
Default How do you change turn signal bulbs?
One is out and one is the wrong color, how do you change the bulbs?
Old 09-14-2007, 12:20 PM
EDS01SS's Avatar
LS1Tech 20 Year Member
well im not sure if you are asking about front or back so I will tell ya both. If you need to change the fronts the easiest way I have found is to remove the headlight. This will give you alot more room to get your hand down there.Once you do that there is a little lever on the socket that you must squeeze while turning the socket. Once the socket is loose then just pull the socket out of the lense housing.Now if your are trying to change the rear bulbs then just pull the carpet back in the trunk area and you will see 6 large black wingnuts. Unscrew those and remove your taillight and from there its the same procedure as the front.
Old 09-14-2007, 01:11 PM
sscamaroburn02's Avatar
just removing the headlight is the easiest way. There is one 10mm bolt i believe and once you remove it just slide the headlight and with a little care it will come out.
Old 09-14-2007, 01:21 PM
SleeperD's Avatar
I'm assuming it's a TA from your screenname. From under the car there is an access panel underneath where the parking light fixture is on both sides (in front of the tire.) Remove the 2 10mm bolts and the panel drops down. Reach up and grab the light plug and twist, extract from turn signal housing, replace bulb. Installation is reverse of removal.
Old 09-14-2007, 09:39 PM
TA1364's Avatar
Sorry its the front bulds. Going from under the car there is barely anyroom but im afraid of messing up the headlights unscrewing them. Ill try going from the top anyway
Old 09-14-2007, 09:54 PM
steveb1's Avatar
If we're talking about a TA, just stick your hand in the hole in the bumper just below the turn signal housing. Twist the pigtail out of the housing, swap the bulb and put it back in.
Piece of cake, I do it all the time.
Old 09-15-2007, 05:57 PM
SMKD6's Avatar
Default Tips on replacing the pigtail?
Socket looks fried. How do you replace the pigtail? Getting tired of replacing the bulbs every other week.
Old 09-15-2007, 05:59 PM
SMKD6's Avatar
Default sorry
Didn't mean to hijack your thread. Any help would be appreciated.
Old 09-15-2007, 08:12 PM
Copy & Paste Moderator
VIP1's Avatar
Cut it off and splice in a new one from AutoZone for $8.
Old 09-15-2007, 08:40 PM
SMKD6's Avatar
Thanks for the help VIP1! I really apprciate it!
Old 09-16-2007, 08:38 AM
EDS01SS's Avatar
DO NOT use butt connectors either unless you want a bunch of nasty electrical gremlins later on
Old 09-16-2007, 12:00 PM
VIP1's Avatar
I'd recommend solder and heatshrink tubing. Thats how I replaced my headlight connectors (solder and heatshrink tubing).
Old 09-18-2007, 11:37 AM
DetroitDrillSGT's Avatar
Whats the part # from Autozone for the sockets? I am in MD and the one near me doesnt stock them.
thanks
Old 09-18-2007, 04:15 PM
VIP1's Avatar
I don't remember the part #, but it'll say on the package that its for GM applications that use a 3157 bulb.
Old 09-18-2007, 05:02 PM
UCABlackChevy's Avatar
85881, I know off the top of my head cause I've done it twice in the last couple of months.
Old 09-18-2007, 05:12 PM
Autozone lists that part as the rear socket, does it work for the front also?
Old 09-18-2007, 06:40 PM
Starion's Avatar
LS1Tech 10 Year
Yep. Not sure about the rear but I used it for the front. Make sure your housing isn't letting moisture in or you'll be doing this again. If it is, replace it. In addition, use dielectric grease at the bulb connection to keep moisture out.
Old 09-19-2007, 02:23 PM
TA1364's Avatar
Ok I finally got the bulb to pop down, but now how do u get it out of the socket? I must be retarded...
Old 09-19-2007, 06:11 PM
VIP1's Avatar
To remove the connector from the housing: twist and pull.
To remove the bulb from the connector: pull
(Sometimes they are stuck, just pull, wear gloves if you are worried about the bulb breaking in your hand.)
Old 09-20-2007, 03:53 PM
TA1364's Avatar
Next problem...finally got the new bulbs in, one side still doesnt work. I took out the socket and its fried, went to dealership they said have to buy entire new setup for $65 and splice the wires together. Pain in the Azz!! Is there anyway to just get just the socket or chances are the thing the socket goes in is fried too?
Quick Reply: How do you change turn signal bulbs?
