New Engine Help Please...
Old 06-01-2003, 06:10 PM
T/A Medic's Avatar
Default New Engine Help Please...
having new engine issues...
i took the intake off yesterday before I went racing to change the oil sending unit... found the intake ports of the heads covered in oil, intake coated in oil.. etc etc... car was down a quart of oil after 200 miles...
engine had 500mi on it approx... babied for 350 of them.
Called the engine builder and we did a leak down on it...
we only did 3 of 8 cyls ... one had 8% the other two had 25%... so whats that all mean?
Not too happy at the moment.
Stock Crank, Diamond 3.905 pistons/rings/pins
only good note of the day was a wheels up 12.1 run ... thanks
Old 06-02-2003, 10:40 AM
T/A Medic's Avatar
Default Re: New Engine Help Please...
ttt
Old 06-02-2003, 12:59 PM
strokedls1's Avatar
My friend just added a catch can after the same situation, and that helped the problem. Running 20-50 also improved the oil usage. If you have thin rings you should expect some leak through. No big deal though.
