can i get a better 60Ft?
mods in sig on Mt et streets
22psi 4800rpm launch 1.835 12.67
22psi 5000rpm launch 1.922 12.69--had a some tire spin so i lowered the psi
20psi 5000rpm launch 1.839 12.57
went a lil higher on the launch 5300-5500 and got a 1.771 12.54
the da was around 1800-2100. with more rpm on the launch a lower da do you think i can get a 1.6X with a 12.3x?
I run my tires at 12 to 14psi hot. I run the M&H Racemaster 26x11.5x15 cheeter slick and luanch at 6,000 to 6,500 with no spin. Even when I had the same tire but in a 16'' rim I still had no tire spin. Next time drop it to 15psi and work up or down from there. Make sure your tires are getting hot while doing your burnout(seeing smoke) so they grab better.Your car has 12.2 or 12.3 in it easy. get it out of the hole and hit those gears and you'll get it.
