Wheres a good place to find a 99-02 wiring harness?
would they be good for my RX7? What im saying is..if I bought their harness for 750$ would it work with an 02 PCM and not have to be further modified?(some companies do harness mods for 400$ to make it so it can hook up to the RX7..and I dont wanna buy a new harness then have to hack it up and spend all that money)
If youre looking for an ls1 engine harness, Im sure you know it wont be cheap, but a junk yard is probably the cheapest available option. I did a search on car-part.com, which shows all of the salvage yards around the country and if they have the part in stock. ended up picking one up for around 250-300 dollars, I forget exactly how much.
Originally Posted by Z06kern
When I built my 67 Firebird with an LS1 in it, I had Speartech make a custom harness with just the bare bones stuff I needed to have to race the car. I then got a PCM for a 02 Camaro SS and hooked the harness up and everything worked great. He can make the harness any length you want so it will fit in the car good. I did have to tune the car with HP tuners to dial in everything and turn off all the different error codes I got from deleting things on the harness such as air conditioning, VATs, ect. It won't be your cheapest option but, if you want a quality harness with just the stuff you need to run the car its a great product. Hope that helps!
All the plugs have labels on them. They send you a sheet of paper that shows the complete harness and explains most of the connections you will have to make. As long as your using an GM PCM your not going to have any trouble. I would just give them a call and explain what you want to do.
